overhead broadcast / paging system product!!!
4.13 with bunch of MGCP T1 PRI and FXO voice gateway.
We are going to have overhead broadcast at warehouse.
I have three questions, what is the benefit intergrate with CCM4.13??
And any suggestion about any overhead broadcast product (cost effective, easy to install, configure, easy intergrate with CCM and manage).
What kind of equipments (modules) that I need to intergrate with CCM4.13.
Ken
Overall Rating: 5 (7 ratings)
dennisleduc Tue, 10/24/2006 - 06:18
We use an Andtek solution. (www.andtek.com) in particular the andtek broadcast solution. Although this is typically restricted to an IP phone as the actual paging device. Just a thought.
jpattishall Tue, 10/24/2006 - 06:27
I usually use Boegen self amplified speakers, and a Boegen UTI. Then all you need is an FXS card or an ATA. It is the cheapest way to do it if you are looking for overhead paging--if you want to use over the phone too; i agree with the other post or Berbee.
Jason Hamlett Tue, 10/24/2006 - 09:09
Agreed with the overhead stuff, but if anyone is looking for over the phone paging, Syn-Apps SA-announce is fantastic.
gsidhu Wed, 03/23/2011 - 13:30
Does anybody know if the Bogen TAM-B is compatible with Cisco FXS module?
My client has ordered a couple of VIC3-4FXS/DID modules and wants to know if can be used to link the Bogen Paging solution via the TAM-B.
Rob Huffman Tue, 10/24/2006 - 06:46
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ken,
Here is a little added info to Dennis and Jans good posts;
Good paging tech notes
Using Analog E&M Ports to Interface to Overhead Paging Systems
http://www.cisco.com/warp/public/788/signalling/e_mpaging.html
Verify and Troubleshoot the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017b2ad.shtml
The two most popular Overhead paging systems are Valcom and Bogen;
Valcom Paging
http://www.valcompagingproducts.com/?pid=1219&utm_source=GGL&utm_medium=cpc&utm_term=valcom+paging&utm_content=Valcom&utm_campaign=Mfg
Valcom VoIP Paging
http://voip.valcom.com/
Bogen Paging
http://www.bogen.com/
Hope this helps!
Rob
hbarrera2 Tue, 10/24/2006 - 08:22
I believe if you use an FXS port off of the MGCP gtwy and connect it to your overhead paging amp. Typically the amp will be bogen or viking.
timmektrakarn Tue, 10/24/2006 - 08:39
If you use an FXS port you will also need to use a Telephone Access Module (Bogen TAM-B) from each system.
Tommer Catlin Tue, 10/24/2006 - 10:48
  • Green, 3000 points or more
all suggestions are great. I have also seen.. never have done it.... someone take apart a 7940 and stick it in the ceiling. They wired a speaker to the built in speaker and amplified it to the ceiling mounted speaker. Configured the 7940 using PLAR and whamo.... overhead paging.
enjoy todays hack of the day.
Rob Huffman Tue, 10/24/2006 - 13:07
  • Hall of Fame,
    Founding Member
Hey Tommer,
I love that idea, all we need is some barbed wire and duct tape!!
Take care,
Rob
Tommer Catlin Tue, 10/24/2006 - 15:05
please rate if helpful.
(just jokin)
Did you see the one in the Unity forum? Guy wants the same thing, but for an MWI light in a general area... told him to take the phone apart and re-wire the Msg waiting lamp to a bigger bulb.
Chris Deren Wed, 10/25/2006 - 05:51
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Guys this is good stuff, I love the creativity and out of box thinking ;-)
