Warning message
Recommendation
Oct 24th, 2006
Hi Guys!
What router do you recommend me with dual wan? I reviewing the 1811.
Actually i have two isp?s, one with DSL an other with fiber optic, when one fails, I change the connection to the other manually and reconfigurate for the VPNs (5 VPN)
Please see the attached files.
Thank you for your time!!!
dpopli Tue, 10/24/2006 - 21:24
Use 1721 with WIC cards
Rate if it helps
globalnettech Wed, 10/25/2006 - 01:24
  • Silver, 250 points or more
depending on the type of connectivity you have with your ISP's, the 1811 (with two 10/100 FE WAN ports) might not be what you are looking for. Have a look at the 1841 instead as well, which is a modular router, with a lot of flexibility with regard to interface cards. Here is the link to the data sheet:
Cisco 1800 Series Integrated Services Routers: Cisco 1841 Router (Modular)
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016a59b.html
GNT
