HSRP /VRRP
Oct 24th, 2006
We've two cisco routers (1750,1841)in a site and 2 ISPs one for each router. If we need failover and load balancing then what is the sollution? Is there any solution other that HSRP,VRRP ,GLBP?
spremkumar Thu, 10/26/2006 - 03:25
  • Red, 2250 points or more
Instead of looking out for the above said redundant protocols you can connect the link onto a same router or in different routers and have BGP between your ISPs.
Do remember that you need to have your own ip block in place to have the same configured in your box..
regds
