Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi anyone can assist me on the VPC configuration ? The status not up. VPC Status : switch(config)# show vpcLegend:(*) - local vPC is down, forwarding via vPC peer-link vPC domain id : 700Peer status : peer link is downvPC keep-alive status : Suspende...
Muhd by Level 1
  • 99 Views
  • 3 replies
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
Is it necessary to change the MTU for SVL links in a scenario in which interfaces are configured with MTU larger than default 1500 bytes?Traffic could flow between chassis through SVL links in a Stackwise Virtual cluster. Could not find any reference...
ckuwajima by Level 1
  • 95 Views
  • 3 replies
hii have cisco 6500 series core switch and facing a bizarre issue with data speed transfer.I have two vlans svi for which is defined on this switch (core6500). these vlans are transported to another switch (sw5) via lacp etherchannel which is providi...
Wonxie by Level 1
  • 101 Views
  • 4 replies
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 153 Views
  • 4 replies
Resolved! mac flapping
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
Resolved! PBR VS CONNECTED
hello. I understand that Connected routing has an AD value of 0. The IP bands on the 1st and 2nd floors are different. 1st floor: 1.1.1.0/242nd floor: 2.2.2.0/24 There are two firewalls on top of the backbone. The band will be 3.3.3.0/24. If you conf...
김선명 by Level 1
  • 235 Views
  • 8 replies
I get the following error message: https://pastebin.com/WEwAvbsCThe network is shown in the image. I literally just press start all devices, connect to console and get that. I tried googling the error but nothing shows up.
The VLANIF of the core switch acts as the gateway for client. The Client is unable to obtain the gateway IP, but by manually adding ARP, it can communicate with the gateway. The core switch has the correct MAC and ARP information for the client, a...
Translator by Community Manager
  • 140 Views
  • 4 replies
