Warning message
Prioritization (QOS) for Citrix
Answered Question
Oct 26th, 2006
Hi all,
I tried to apply QOS for Citrix traffic to one of our remove sites. For me the configs seems to be right, but for some reasons the prioritization is not working out. I also enabled ip nbar on the atm interface. Can some one help me out in fixing up the issue.
Note : In the below output only 2 packets are seen to be captured. But i know the whole link is used for the Citrix traffic transfers.
class-map match-any CITRIX
match protocol citrix
match access-group 110
class-map match-any RDP
match access-group 103
policy-map OUTBOUND
class CITRIX
priority percent 50
class RDP
priority percent 10
class class-default
fair-queue
access-list 103 remark RDP-Priorisation
access-list 103 permit tcp any any eq 3389
access-list 110 remark Citrix-Priorisation
access-list 110 permit tcp any eq 2598 any
access-list 110 permit tcp any any eq 2598
access-list 110 permit tcp any eq 1494 any
access-list 110 permit tcp any any eq 1494
Service-policy output: OUTBOUND
Class-map: CITRIX (match-any)
2 packets, 94 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol citrix
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group 110
2 packets, 94 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 50 (%)
Bandwidth 256 (kbps) Burst 6400 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Rajesh
Hi Rajesh, I see from youe above output that RDP class is matching quite a bit of traffic now so it looks like it is working although there are still only 3 matches on the Citrex class. As nbar protocol discovery did not match any citrix traffic it's looking like either there is no citrix traffic hitting the router or it's not on the standard port-map that nbar uses. Can you confirm the port your citrix traffic is using?
r1#show ip nbar port-map
port-map bgp udp 179
port-map bgp tcp 179
port-map citrix udp 1604
port-map citrix tcp 1494
Overall Rating: 4.5 (2 ratings)
can you enable "ip nbar protocol-discovery" ont the inbound interface for traffic hitting the router. The do "show ip nbar protocol-discovery" to see if any traffic is matching the NBAR protocol groups. If traffic is hitting the router as expected can you show the config of the ourbound interface where the service polciy is appiled?
mheusinger Thu, 10/26/2006 - 03:44
  • Green, 3000 points or more
did you overload the interface with traffic? If not, the counters will not encrease. The reason is, that the counters will not "see" packets CEF or fast switched. Only those packets queued will be seen, as only those will have to be treated by the CPU of the router.
You are doing CBWFQ and this is only invoked, when there is an overload situation. So use a traffic generator and make sure you get some drops as a sure indication of overloading the interface. If the counters still are not increasing, then the policy does not work and further investigations are needed.
Regards, Martin
mheusinger Thu, 10/26/2006 - 04:22
Yes I did and the same answer is applicable in both cases. The counters might just be zero or "low" because not every packet is counted, which is forwarded by the router. If this is the case - in both posts to be verified - there is no problem, but only the default behaviour encountered.
The link to read about this is:
"Understanding Packet Counters in show policy-map interface Output"
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
Regards, Martin
EDIT: Having a closer look at the counters in both cases there are practically no dropped packets in the default class. This could very well mean, that no congestion for the classes in question has ever been experienced.
mheusinger Thu, 10/26/2006 - 04:33
To the original poster:
Can you configure a policer, which counts every packet? Could look like this:
policy-map MyMap
class MyTraffic
police 1000000
conform-action transmit
exceed-action transmit
violate-action transmit
bandwidh ...
This policer will only be used as a packet counter. If this will not give any matches, have a closer look to your ACL. Does it really match your traffic? Consider using NBAR "match protocol citrix" only and adjust the TCP/UDP port maps for citrix.
Regards, Martin
kradjesh13 Thu, 10/26/2006 - 05:31
Hi Mark / Martin
I applied the ip nbar command in the ethernet interface and still i don't find any citrix traffic being captured. In the WAN interface not only citrix but almost every counter is 0 and its some thing real bizza.
interface FastEthernet0/0
description XYZ LAN
ip address xxx.xxx.xxx.65 255.255.255.240
duplex auto
speed auto
#sh ip nbar protocol-discovery
ATM0/0/0.1
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
bgp 0 0
0 0
0 0
0 0
citrix 0 0
0 0
0 0
0 0
cuseeme 0 0
0 0
0 0
0 0
custom-01 0 0
0 0
0 0
0 0
custom-02 0 0
Martin, i have overloaded the router with Citrix traffic and even i find difficult to type the commands since such a very heavey citrix traffic is being generated. But still no use
Any how thank for all your tips.
Rajesh
kradjesh13 Thu, 10/26/2006 - 05:57
Yes, i checked the configs to the interface in which i applied ip nbar commands. For your reference i pasted the outputs which i took from the WAN interface. So ip nbar command is applied on both the interfaces which is ATM and FastEthernet interface.
Virtual-Access2 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
reliability 255/255, txload 23/255, rxload 1/255
Encapsulation PPP, LCP Open
Open: IPCP
PPPoATM vaccess, cloned from Dialer1
Vaccess status 0x44
Bound to ATM0/0/0.1 VCD: 1, VPI: 8, VCI: 35, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 5 seconds on reset
Interface is bound to Di1 (Encapsulation PPP)
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 1w2d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 48000 bits/sec, 0 packets/sec
6509640 packets input, 536627972 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
10042284 packets output, 3551444033 bytes, 0 underruns
0 carrier transitions
sh policy-map interface atM 0/0/0.1
ATM0/0/0.1: VC 8/35 -
3 packets, 141 bytes
0 packets, 0 bytes
5 minute rate 0 bps
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 50 (%)
Class-map: RDP (match-any)
3333 packets, 352492 bytes
Match: access-group 103
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 10 (%)
Bandwidth 51 (kbps) Burst 1275 (Bytes)
(pkts matched/bytes matched) 111/17057
(total drops/bytes drops) 3/4091
Rajesh
Correct Answer
kradjesh13 Thu, 10/26/2006 - 06:45
Yes mark i can see the ports 1604 and 1494 when i did a show ip nbar port-map.
sh ip nbar port-map
port-map cuseeme udp 7648 7649 24032
port-map cuseeme tcp 7648 7649
port-map dhcp udp 67 68
port-map dns udp 53
port-map dns tcp 53
sh access-lists
Extended IP access list 103
10 permit tcp any any eq 3389
20 permit tcp any eq 3389 any
Extended IP access list 110
20 permit tcp any any eq 2598
30 permit tcp any eq 1494 any
40 permit tcp any any eq 1494 (3 matches)
50 permit tcp any eq 1604 any
60 permit tcp any any eq 1604
Only three packets are matched with port 1494. When i did a "bebug ip packet 110 detail" i couldn't see any packets matching ACL 110.Is there any other commands or debug comands to check the ports for the existing traffic.
Rajesh
mheusinger Fri, 10/27/2006 - 02:07
it looks to me as if your CITRIX implementation does not use the ports NBAR is looking for. Can you check the ports CITRIX is using, or whether there is any tunneling/encryption applied to CITRIX traffic. The last thing that could happen: are you sure about CITRIX or could it be MS remote desktop or other stuff?
Just for testing I would specify the CITRIX server IP and not be port specific in the ACL.
Regards, Martin
kradjesh13 Fri, 10/27/2006 - 07:01
Thanks for your help guys..
Today morning i noticed that the packets are being captured and working fine. As Martin said, thinking of discussing with the Citrix administrator to know the exact ports and to apply ACL's for better performance.
Once again thanks for all your help and support.
