fiber optic switch
Oct 27th, 2006
i want to know what is the best distribution switch to use to connect to access(2950 with FO)through Fiber.i want to connect 14 of this switches to a 4506 core switch and plenty of access switches(2950 with FO)
sachinraja Fri, 10/27/2006 - 04:26
  • Red, 2250 points or more
really depends on the scenario.. for any requirement which has more than 4 uplinks, we will have to look for a 4500 or a 6500... if you want to connect 14 uplinks, you can basically look for a 4506 (withouth sup redundancy) or 4507 (which has SUP redudancy) or a new brand of 6500's which is 6504 E with SUP 32 (which will have 8 fiber ports).... featureset wise, 6500 is far superior to 4500...
hope this helps.. all the best.. rate replies if found useful..
Raj
kofflerg Fri, 10/27/2006 - 14:37
Another alternative (inferior to 6500, but better than 4500 IMO) is a 3750 stack using the 3750G-12S.
George
