Warning message
ios upgrade for vpn 3005
Answered Question
I'm running this ios version on vpn 3005:
vpn3005-4.0.4.A-k9.bin
What is the upgrade that I need to perform:
vpn3005-4.1.7.O-k9.bin OR
vpn3005-4.7.2.I-k9.bin
Please advise,
yanic
Correct Answer by ajagadee about 10 years 9 months ago
Yanic,
In your case, you can upgrade either upgrade the VPN3005 to 4.1 or 4.7 and both should be OK. Make sure that you have sufficient RAM to upgrade to 4.1 or 4.7 code and read the release notes in detail to avoid surprises
Release Notes:
4.1
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/417fcn3k.htm#wp28723
4.7
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_7/472con3k.htm
I hope it helps.
Arul
** Please rate all helpful posts **
Overall Rating: 4 (1 ratings)
Correct Answer
ajagadee Tue, 10/31/2006 - 18:50
  • Cisco Employee,
Yanic,
Release Notes:
4.1
4.7
I hope it helps.
Arul
credit123 Tue, 10/31/2006 - 21:46
you should go for vpn3005-4.7.2.1-k9.bin, rest upto you.
