AP stuck in startup - output
Answered Question
Oct 27th, 2006
Hi, anyone can help on this ?
I power cycle my Cisco Access Point (Aironet 1200 series) connected thru console cable to my PC.
On Hyperterminal, I notice that after certain initialization outputs the startup process 'freezes' always at the same point. I already did power cycle the device multiple times, no improvement.
I use my console cable and PC to successfully manage other devices, therefore I am ruling out that as being the problem.
Any ideas why this is happening to my access point and how can I fix it ?
Please find attached output of hyperterminal captured at the moment where the output from the startup 'freezes'.
Correct Answer by Stephen Rodriguez about 10 years 9 months ago
What settings to do you have on your terminal emulator? Should be 9600, none, 8, 1 and no flow controll.
Overall Rating: 5 (2 ratings)
scottmac Sat, 10/28/2006 - 05:30
  • Green, 3000 points or more
Is the AP operational? Can you connect to the WebGUIthrough either the Ethernet port or wirelessly?
Do you have flow control set to "None" on our HyperTerminal?
Let us know
Scott
Correct Answer
Stephen Rodriguez Sat, 10/28/2006 - 10:20
  • Purple, 4500 points or more
news2010a Mon, 10/30/2006 - 07:25
Hmmm, I think it was the Hyperterminal setting. I put 'no flow control' and that did it. Thanks all.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
