VLAN interface Keepalive in FWSM & ASA 5540
Oct 29th, 2006
Dear All,
I have config VLAN in FWSM Routed mode.Now i have to prepare auto redundant set up for this with ASA 5540.But my problem is that when primary connection in FWSM fails VLAN which is config is never goes down ,so route is not flush from FWSM routing table.My requirement is that
1) when FWSM first ethernet goes down it should make VLAN down so that i can route same traffic on other VLAN with higher metric to achieve auto redundancy.
TIA
SAM
vmoopeung Fri, 11/03/2006 - 06:34
  • Bronze, 100 points or more
The routing table can be cleared by issuing the command clear ip route*. This makes the neighbors to resend the hello packets to each other and form new nieghbort relationship.This inturn will make the neighbors to learn the new route and reliable route.
safe Mon, 11/06/2006 - 08:21
Thanks for reply,
Your solution is use when i am using routing protocol but i m not using any routing protocol.I want it through static routing .
SAM
