ISDN used timer
Nov 2nd, 2006
i have configured un ISDN backup connections to un CDN.
I have not traffics DDR because the CDN connections is UP, but when i do:
show isdn status
the output is
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In ---N/A--- ---N/A--- +1-extranet +57362
the parameter second used is incrementing.
I try different debuge but i have not output.
Any body can help mi to understand why ?
Best regards
spremkumar Thu, 11/02/2006 - 06:28
  • Red, 2250 points or more
Hi Amand
Can you check up the config which mite be allowing any kinda traffic to trigger the isdn and keep it on.
regds
smothuku Thu, 11/02/2006 - 07:15
  • Silver, 250 points or more
Hi ,
can you paste the config ? Have you configured the ISDN backup commands on primary interface.
You are getting incoming call from extranet+57362.Better check the config at remote end also.
Satish
AmandMimoza Wed, 11/08/2006 - 07:17
Here is the configuration on both site, remote and central site.
The name +1-extranet is the a part of the name?s router central site and the number that in incrementing +80176 are the seconds busy connections.
Central site
interface Serial4/0
description Link vs
bandwidth 2048
ip address x.x.x.x y.y.y.y
backup interface Dialer5
no ip mroute-cache
load-interval 30
serial restart_delay 0
end
interface Dialer5
description Dialer group controlling the BRI1/4-BRI1/7
encapsulation ppp
dialer pool 5
dialer remote-name bbbbbbb
dialer idle-timeout 900
dialer string 0257515249
dialer string 0289263551
dialer string 0257516908
dialer string 0257516910
dialer load-threshold 1 either
dialer max-call 8
dialer-group 5
no cdp enable
ppp authentication chap
ppp multilink
end
interface BRI1/4
description ISDN number
no ip address
encapsulation ppp
dialer pool-member 5
isdn switch-type basic-net3
isdn point-to-point-setup
no cdp enable
ppp multilink
end
Remote site
interface Serial0/0
description link verso
bandwidth 2048
backup interface Dialer1
no ip mroute-cache
interface Dialer1
description Dialer group controlling the BRI1/0-BRI1/3
ip address 10.56.143.158 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name RRRRRRRRRR
dialer string 0248376621
dialer string 0248376036
dialer string 024125322
dialer string 024125261
dialer max-call 8
dialer-group 1
no cdp enable
ppp multilink
end
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp multilink
end
Mimoza
sap_arun04 Wed, 11/08/2006 - 13:42
why are u configure dialer string in both end. i hope remote end will be dialing to Central site when primarry link is going down.
pl.clearfy this
sap.
smothuku Wed, 11/08/2006 - 13:55
Hi Mimoza ,
Are you dialing from remote site to central site or from central site to remote site ?
satish
