Warning message
QoS Question
Nov 2nd, 2006
I am implementing QoS in large data centers with Catalyst 6500 (SUP-720). We don't use Layer-3 routed interfaces, but only Layer-2 802.1Q trunks and VLAN interfaces. Is it correct to say that I cannot use classical PQ, WFQ and CBWFQ as in traditional routers, because the PFC is actually switching packets at Layer-3 and no packet flow through the MSFC ?
Thank you
Yves
Overall Rating: 5 (1 ratings)
gpulos Thu, 11/02/2006 - 07:52
  • Blue, 1500 points or more
if you only have a layer2 engine to provide QoS, then you can classify traffic at L2 using destination MAC address, VLANs and marking L2 CoS (class of service) values.
(using only the switching queues on the port)
you will not be able to use L3 IP precedence or DSCP values to classify or mark traffic.
(since you have no PFC)
since PQ, WFQ and CBWFQ require the PFC, then you would be correct in your statement that you cannot use either of these without the PFC.
please see the following link for the CCO supplied answer to 'can you implement QoS without a PFC?':
http://cisco.com/en/US/products/hw/switches/ps708/products_qanda_item09186a00804d2e3a.shtml#q7
