Warning message
FWSM: deny tcp/113 w/reset
Nov 2nd, 2006
If tcp/113 (auth/identd) is denied explicity or implicity by an access list, is a reset sent to the source by default? If not, how do you configure the fwsm so that it sends a reset in this case? This would be so that outbound email connections dont hang if the destination server sends an identd request, and has to wait for it to timeout before it processes the smtp session.
Larry Owen
Overall Rating: 5 (1 ratings)
lowen Fri, 11/03/2006 - 06:48
That's the ticket! Although, if I read the description right in the command reference, this will send resets for all denied tcp syn's. You'd think there would be an argument so you could selectively send resets based on the tcp port being accessed. Anyway, thanks!
Larry Owen
