TCL Scripting
dgahm Thu, 11/02/2006 - 12:29
  • Blue, 1500 points or more
You should be able to. We use the old srst_CISCO.2.0.0.0.tcl canned script which normally sends calls to a defined pilot number, and when the number is unreachable it plays a greeting, and allows the caller to dial an extension, or 0 for an operator extension that is defined.
This script was designed to be used with SRST in a Call Manager environment, but it should work fine in CME. You could either modify the script, or just define a bogus unreachable number to turn on the autoattendant all the time.
Not sure if the this is still available as a download from CCO, but if you want it I could email it to you. It was SRST2.0.zip
Please rate helpful posts.
