Accidentally deleted files from Flash
Nov 5th, 2006
Hi all
I've accidentally erased the files located in Flash of a Cisco 877W router. Below are the files that I've deleted:
1. c870-advsecurityk9-mz.124-6.T1.bin
2. sdmconfig-8xx.cfg
3. es.tar
4. common.tar
5. home.shtml
6. home.tar
7. wlanui.tar
8. 128MB.sdf
9. vlan.dat
I've got no problem with restoring the IOS file but cannot find the other files on CCO. Can someone point me in the right direction? Thanks.
vincent-n Sun, 11/05/2006 - 21:29
I've managed to fix my own problem by installing Cisco SDM on the router.
spremkumar Sun, 11/05/2006 - 22:39
  • Red, 2250 points or more
hi vincent
you dont need those files excpet .bin(ios) unless you want to run SDM.
As you know IOS is required for the router to boot up and do the required/desired functions based on the configs done.
regds
