Warning message
Delete old configuration on 2950
Answered Question
Nov 6th, 2006
I just upgraded the IOS on a 2950, but now I need to clear out the old VLANs. Is there anything else I need to clear out so that I can start off fresh?
Correct Answer by ankbhasi about 10 years 9 months ago
Hi Friend,
Clear the config a well as vlan.dat file.
delete flash:vlan.dat
Ankur
*Pls rate the post if it helps
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Mon, 11/06/2006 - 00:09
  • Cisco Employee,
Hi Friend,
Ankur
gongjuntao Mon, 11/06/2006 - 00:46
Hi djgizmo250
you just need to it like that,
wr
reboot
