Warning message
NAT issue on CSS11506-2AC ConServSw with 7.04 version
Nov 7th, 2006
Hi All,
I have CSS11506-2AC ConServSw and the Problem is sometimes the dst nat is 0.0.0.0 and sometime there is ip address.
here is the nat table:
1)
172.25.11.171 8080 84.149.88.240 56618 84.149.88.240 TCP 4/2 4/1
2)
172.25.11.171 8080 134.109.96.124 46851 0.0.0.0 TCP 4/2 4/1
Kindly let me know wheather is this the known problem are there is some issue with the css switch.
Any reply will be greatly appriciated.
Thanks in advance
Gilles Dufour Tue, 11/07/2006 - 23:19
  • Cisco Employee,
the 0.0.0.0 simply means 'don't nat'.
We would need the config to see what's going on.
Also, is the entry non-zero initially and then switching to 0.0.0.0 ?
Does it break any connectivity ?
Could you capture a sniffer trace of a failure.
Is it happening for specific client or all of them ?
All the time or just sometimes ?
Gilles.
inayathulla1 Wed, 11/08/2006 - 01:58
Hi Giles,
After checking the active CSS I can find the same 0.0.0.0 so I guess you can use the showtech.out of this box as well ;-)
Attached you can find the showtech.out and the show flows output.
many thanks in advance
Inayath
