Warning message
Extended Authentication (Xauth)
Nov 7th, 2006
Is it possible to use extended authentication (X-auth) to do a double authentication first one at group level against a RADIUS ?based token server and then a new authentication against the Active Directory to be able to map user group -mappings from AD- groups to ACS groups?
The goal is to be able to use a token based password (OTP) for authentication and then be able to authorize the user against the AD.
If there anyway to solve this or a best practice, please let me know.
Thankful for any help or inputs on this
Best regards.
// Dunken
jasjsingh Tue, 11/07/2006 - 10:19
Yes this is possible, let me know the the device you are using to terminate the VPN connections .
dunken_swe Tue, 11/07/2006 - 23:04
Hi, thanks for your reply.
The thought is to use Cisco ASA5020/VPN3030 to handle the request from the incoming VPN-connections.
