How to extract 911 report from Call Manager
Answered Question
Nov 7th, 2006
Hi, It has been requested I provide a report showing only 911's and where they are originating. Does Call Manager have a utility I can use to extract this data?
Thanks to all in advance, it is greatly appreciated.
Correct Answer by Rob Huffman about 10 years 9 months ago
Hi Ross,
This is the only method that I know of to do this type of search (in CCM);
Using SQL Queries to Search the Call Detail Record with Cisco CallManager
Search for Calls Made to a Specific Number
In some situations, you might need to find out the extension which called 911 on a specific date. Complete these steps in order to search for calls made to a specific number such as 911.
In order to search for calls that are made to a specific number, you can run a different query.
For example, if you want to look for calls to 911 you can enter the query select * from CallDetailRecord where finalcalledpartynumber='911'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911.
Add a date to this query in order to refine it.
For example, for all calls to 911 after August 1st, 2003, run the query select * from CallDetailRecord where finalcalledpartynumber='911' and datetimeconnect > '1059696000'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911 made after August 1st, 2003. '1059696000' is the universal time in seconds for August 1st, 2003.
In order to see who calls 911, run the query select callingpartynumber from CallDetailRecord where finalcalledpartynumber='911'.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.....
Overall Rating: 5 (1 ratings)
rossporubski Tue, 11/07/2006 - 09:10
Hi, thank you for responding.
The search facility has only default functionality:
By User/Extension
By Gateway
By Cause for call termination
By Call Precedence level
Malicious call
It doesn't have an open criteria option.
dgahm Tue, 11/07/2006 - 09:37
  • Blue, 1500 points or more
When you search by extension, that number can be either the calling number or the called number. This is where you would put the 911.
I have used this to identify what internal DN placed a 911 call.
dgahm Tue, 11/07/2006 - 10:22
We moved a group of users to a different site yesterday, and so the techs were supposed to do a test 911 call.
To verify I did a CAR search on 911 for yesterday. The test call was there, as well as a surprising number of misdialed calls where the user had dialed 911 and gotten the "your call can not be completed as dialed".
We dial a 9 access code for all calls including 911. The CAR search shows that if we allowed users to dial either 911 or 9911 (some places have regulations mandating that)there would be a lot of false 911 calls. Perhaps that is your situation?
Correct Answer
Rob Huffman Tue, 11/07/2006 - 09:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ross,
From this doc;
Hope this helps!
Rob
