Warning message
WS-C6513 port shutdown
Nov 8th, 2006
I have one problem regarding WS-C6513 switch using CatOS command. I notice that the ports connect from the user to the module ports will keep on shutdown for no reason. The worse part is i have to unshut the port one by one. It really waste a lof of time.
Sometimes i receive some messages in the logging buffer as port-security violation followed by some mac address.
The problem is the desktop did not change any mac address. All the while, the desktop is connected to the IP Phone. It just happen that the port security keep on showing violation then shut the port.
The user side sometime connected to IP Phone. Then from the IP Phone, the cable are then link to the user Desktop.
When i go in to show the ErrDisable Reason for that port, nothing was shown for the status of the port. My errdisable-timeout interval is 300 seconds.
I have already enable arp-inspection, bpdu-guard, channel-misconfig, duplex-mismatch, udld and others inside the errdisable-timeout.
1) How to solve the problem so that the ports will auto unshut?
2) Is it because of the image version so i cannot used the auto unshut features or see the ErrDisable Reason? I am currently using cat6000-sup32pfc3k8.8-5-1.bin image.
3) Or is it a software bug for CatOS? I did not face any of this issue using Cisco IOS.
4) Is it because of the IP Phone? Currently, all IP Phone did not enable the PoE features. Or it is because of PoE?
5) Lastly, is it because of the commands that i put in?
set port security mod/port enable age 5 maximum 3 shutdown 0 unicast-flood enable violation restrict timer-type absolute
This is the only port security command that i have put in.
paolo bevilacqua Thu, 11/09/2006 - 05:48
  • Hall of Fame,
    Founding Member
Would be better asked in the switching forum perhaps ?
While you appear to be running the latest version of CatOS, consider that it is 1 year old, unlinke new IOS that is released monthly.
