Switchport difference
Nov 8th, 2006
What is the difference between
interface FastEthernetx/x
no ip address
speed 10
duplex full
spanning-tree cost 3100
and
interface FastEthernet7/26
switchport
no ip address
speed 10
duplex full
The first one does not have switchport in the config and the second one has.
Please what is the difference?
Endwigast Wed, 11/08/2006 - 10:44
comment --> the first one is a L3 port.
if he got the output from a router then it's a L3 port but if he got the output from a switch then it's a L2 port
londint Thu, 11/09/2006 - 03:15
Thank you very much.
Does this mean if I omit the swithcport command, I can give the interface an ip addresses?
Endwigast Thu, 11/09/2006 - 03:30
if it's a switch and you command "no switchport" you could put in an ip address and when you do sh run you would see on the int the "no switchport" statement
nilay_wankhade Thu, 11/09/2006 - 03:32
hi,
means that by default,all ports are L3 ports?
pls explain
regards,
nilay
mahmoodmkl Thu, 11/09/2006 - 04:36
  • Gold, 750 points or more
No all the ports will be L2 on the switches except 6500 series.it would be better if u let us know the platfrom which u r using.
Mahmood
Endwigast Thu, 11/09/2006 - 04:37
exactly my point. that's why i asked if what equipment is the port he's referring to.
trick question? :)
Endwigast Wed, 11/08/2006 - 10:42
trick question?
what equipment is fx/x? what equipment is f7/26?
