Warning message
Changed IP. PDM inaccessible.
Answered Question
Nov 8th, 2006
I have a PIX 615 running 6.3. I have changed my IP addressing scheme and as a result, changed my private address on my PIX. I am now able to ping the new private address but I am unable to telnet or gain https access. I even tried a stealth port scan and all ports are reported closed.
Is there a way to recover?
Correct Answer by Fernando_Meza about 10 years 9 months ago
hi .. because you changed you IP scheme .. you also need to modify your ssh and http access before being able to connect to the PIX inside interface.
ssh inside
http inside
I hope it helps .. please rate it if ti does !!!
Overall Rating: 4 (1 ratings)
Correct Answer
Fernando_Meza Wed, 11/08/2006 - 19:56
  • Gold, 750 points or more
ssh inside
http inside
jmclauchlin Thu, 11/09/2006 - 08:55
That was what I was looking for. I was able to poke around and find it when connecting via the console.
