Warning message
2960G Superneting to 2811
Well in the last 4 day i've learned alot. Started with no Cisco experience at all and managed to install and configuer a 2811 with VWIC 2 port T1/E1 card and get the T1 interface and serial subs up/up. Now i'm moving on to the switch. New bigger i assume learning curve.
My Goal is to supernet (trunk all switch traffic to the router and use the switch to break out several isolated dynamic networks and allocat to specified switch ports the few (5) Public Static needed.
I'mm adding a diagram in pdf format each dotted circle = an isolated network or PC. I'll be wanting to connect the Switch port 1 to the FE0/1 port on my 2811 router so i'll alo need to set up that interface. If any help is appreciated. Any additional info needed i can supply.
