ASA 5510 + Failover Active/Standby
Nov 10th, 2006
i try to configure two ASA5510 in a failover szenario. After I have already finished the setup on the primary ASA I try to send the configuration to the secondary. Following Error is shown:
"Unable to configure the firewall at XXX.XXX.XXX.XXX for the following reason:
PDM was not able to determine the context mode of the peer at XXX.XXX.XXX.XXX"
Is this a problem of the context mode? Both ASA?s run in single mode or must there be a special Firewall configuration.
Thank you for your support.
shabiersayed Sat, 11/11/2006 - 00:31
Hi could you please tell me the physical connection of Fail over?
100trocker Sat, 11/11/2006 - 01:09
We have connected a crossover cable on the ethernet 0/3 in between both asa interfaces.
talha_490 Sat, 11/11/2006 - 02:58
Can you send the show version output of the firewall?
check the failover license it has?
100trocker Sat, 11/11/2006 - 04:38
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
This platform has an ASA 5510 Security Plus license.
They are identical on both ASAs.
