CNA 4.1 Installation problem
Nov 10th, 2006
I have the folowing error message after install the CNA:
javaPathString "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\runtime-1.0\bin\javaw"
rootDirPropertyString -DROOTDIR="C:\Program Files\Cisco Systems\Cisco Network Assistant"
classPathPropertyString -classpath
classPathValueString "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\startup-1.11\cna_boot.jar;packages\i18n-1.2\i18n.jar"
mergeClassValueString com.cisco.cpnm.boot.internal.Merge
CreateProcess: "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\runtime-1.0\bin\javaw" -DROOTDIR="C:\Program Files\Cisco Systems\Cisco Network Assistant" -classpath "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\startup-1.11\cna_boot.jar;packages\i18n-1.2\i18n.jar" com.cisco.cpnm.boot.internal.Merge error=3
I have instalated several J2RE version and so far no solution, can someone help me. Thanks
Overall Rating: 5 (1 ratings)
paulo_anica Thu, 11/16/2006 - 10:36
Problem solved.
I have installed CNA 1.0 over version 4.1 and it fixed the problem ??????? :(
