11-10-2006 05:33 AM - edited 03-05-2019 12:44 PM
We are consolidating offices and we have bought a second catalyst 4506. We've assumed that we can simply connect the GBIC uplink ports of the Supervisor II-Plus modules to each other. We'll want to span some VLANs but not all. I'm on the hook to make this work and I've found documentation that almost describes what I think I need to do. Any advice, direction, or words of encouragement will be appreciated. Thanks!
11-10-2006 09:15 AM
Test first! It's straight forward so don't worry too much.
11-10-2006 05:15 PM
Hey man, this is simple, if I understand your question correctly. If you do not want certain VLANs passed on the trunk, follow this;
If you want to allow VLANs 1,3,5 but not 9 or 10, issue the following under the supervisor trunk.
"switchport trunk encapsulation dot1q"
"switchport mode trunk"
"switchport trunk allowed vlan add 1,3,5"
"switchport trunk allowed vlan remove 9,10"
Verify by issuing:
"show interface gig0/0 switchport allowed-vlan"
Please rate if this has helped
11-11-2006 07:23 PM
Did this help?
11-13-2006 05:20 AM
Thanks for the reply! We didn't receive the whole order from Cisco. I'll let you know how it goes after we get the swith up and running...
11-30-2006 07:25 AM
Okay... the rest of the order arrived, the switch was racked, a UPS was installed... And I got access to the switch - yesterday. This was the first time that I've administered more than one switch. I think I'm somewhere in the middle of a learning curve: I implemented VTP (one server, one client) and fiddled around until the number of VLANs matched (show vtp status). I seem to have connectivity (a workstation on the new switch works), but show vlan only lists ports in VLAN 1 (default). Am I missing something?
11-15-2006 01:13 PM
I would utilize vtp pruning if you would like to span some VLANs and not others. More info on VTP Pruning is below.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12225see/scg/swvtp.htm
11-30-2006 07:27 AM
(I finally got access to the new switch yesterday) Do I need VTP with just two switches? Is there a drawback to enabling VTP?
Thanks!
11-17-2006 01:00 AM
Hi... is HSRP running between the switches???
11-30-2006 07:28 AM
I have not explicitly administered (enabled or disabled) HSRP. I've searched cisco.com and will read up. Do you have any specific advice?
Thanks!
