How to confirm NTP server is working on GSS
Nov 10th, 2006
Hi all,
I couldn't find any command to check the GSS is making use of NTP to get the correct time from NTP server. Can anyone please advise how i can check.
Thanks.
Jianwen
skumar1969 Sun, 11/12/2006 - 23:55
  • Bronze, 100 points or more
There are 2 ways to confirm this working. I hope you would have tried the first option. Second option would help more precise.
1/ To view if NTP is enabled for the GSS device, enter:
localhost.localdomain# show ntp
Ntp is enabled
ntp-server 172.16.1.2
ntp-server 172.16.1.3
2/ Use the "tcpdump interface" command to display a record at the CLI of all TCP traffic transmitted from and received by an Ethernet interface. GSS traffic information continuously displays on screen until you press Ctrl-C to cancel the operation.
thanks
gaojianwen Wed, 11/22/2006 - 23:24
Does the following messages show that it's working? Thanks.
#tcpdump interface any protocol any host
tcpdump: WARNING: Promiscuous mode not supported on the "any" device
tcpdump: listening on any
17:41:46.160704 x.x.x.x.ntp > y.y.y.y.ntp: v4 client strat 0 poll 6 prec -17 (DF) [tos 0x10]
17:41:46.435812 y.y.y.y.ntp > x.x.x.x.ntp: v4 server strat 5 poll 6 prec -17 (DF)
2 packets received by filter
0 packets dropped by kernel
