Warning message
Algerian supervisory disconnect
Nov 11th, 2006
Hello I am having problems disconnecting external calls entering through a fxo port,
Has anybody some idea of what are the right parameters to configure a fxo port to support Algerian lines?
Overall Rating: 3 (1 ratings)
paolo bevilacqua Sat, 11/11/2006 - 04:11
  • Hall of Fame,
    Founding Member
Are you sure that Algery supports supervisory disconnect ? Most countries do not.
fjrubiobarcena Sun, 11/12/2006 - 01:16
Hi thanks for your replies, I am not sure if the telco supplies disconnect supervision; I am making test because I have a problem with the externals calls coming from the pstn trough the fxo ports: if the external phone?s user (caller) terminate the call before the ip phone user (called) hang up the call, the ip phone continues ringing and the fxo port continues off hook; the call is not correctly ended.
Have you got any ideas of the cause of the problem?
paolo bevilacqua Sun, 11/12/2006 - 03:31
  • Hall of Fame,
    Founding Member
Indeed the problem is caused by lack of supervisory disconnection. If the telco sends a tone on caller hang-up, you can try supervisory tone disconnection as indicated in the above document.
fjrubiobarcena Sun, 11/12/2006 - 23:23
Hi, thank for your help I have tried the solutions indicated in the document but it still don?t work, I have now this configuration:
voice class custom-cptone dz
dualtone disconnect
frequency 425
cadence 500 500
voice-port 0/0/0
supervisory custom-cptone dz
cptone FR
timeouts interdigit 3
timeouts wait-release 15
timing hookflash-out 500
impedance complex2
