Warning message
Async TTY connection
Nov 11th, 2006
I need to broadcast a async stream of data (at 19.2kbps 8 bits no parity) from central site to multiple sites at remote. Is there an async multicast feature in the Cisco 38xx and 28xx routers that I can use ?
Appreciate suggestions and ideas.
Thank you.
HC
pciaccio Sat, 11/11/2006 - 14:36
  • Silver, 250 points or more
Async is not a protocol that you can send down a router. It has no ability for addressing. What do you want to do with Async? What are you trying to do. Maybe there is another method or protocol you can use....
hcgoh Sat, 11/11/2006 - 20:04
the central site has an async stream of information (in serial interface) to be broadcast/multicast to multiple remote sites simultaneously over MPLS network. The transmission is only one way from central to remote sites.
I understand async BSTUN is available, but is it only for point to point only ?
hcgoh Mon, 11/13/2006 - 18:48
for Async data, the BSTUN does not support point-to-multipoint broadcast application, is there another alternative ?
Please advise.
Thank you.
