Warning message
vpn concentrator reset to factory default
Nov 13th, 2006
Dear Pros,
Please help to solve the following issue.
I set the wrong default static route then i can not access the vpn manager.But i can access thro cli.
In cli need to remove the static route
"0.0.0.0 0.0.0.0 1 192.168.102.1"
Please what syntax to be used.
Static Routes
Destination Mask Metric Destination
0.0.0.0 0.0.0.0 1 192.168.101.1
1) Add Static Route
2) Modify Static Route
3) Delete Static Route
4) Back
VPN4RUW: Routing -> 3
> Delete Which Route (net address)
VPN4RUW: Routing -><here i need to konw the syntax to enter to remove the above static route>
Waiting for your reply
swamy
ajagadee Mon, 11/13/2006 - 11:09
  • Cisco Employee,
Arumugasamy,
What you have entered is a default gateway and you need to change it in a different location:
Static Routes
1) Add Static Route
4) Back
Routing -> 4
1) Static Routes
2) Default Gateways
3) OSPF
4) OSPF Areas
5) DHCP Parameters
6) Redundancy
7) Reverse Route Injection
8) DHCP Relay
9) Back
Routing -> 2
1) Set Default Gateway
2) Set Default Gateway Metric
3) Set Default Gateway Override
4) Set Tunnel Default Gateway
5) Back
Routing -> 1
> Default Gateway
Routing -> [ 192.168.101.1 ] 192.168.102.1
Let me know if it helps.
Arul
** Please rate all helpful posts **
arumugasamy Mon, 11/13/2006 - 13:00
Please advice me the static or deault in the following designs
VPN 3000 in parallel to the pix firewall.
PIX OUT =192.168.102.2
vpn 3000 public =192.168.102.4
pix inside=192.168.101.2
vpn 3000 inside=192.168.101.4
inside connect to core switch with svi ip address =192.168.100.39.
In this design, core switch has default route to pix inside 192.168.101.2.In the pix default to outside internet gataway 192.168.102.1.
Now when we try to make the tunnel from remote client ping ok.
Please tell me about vpn 3000 route config for both public and private interface.
swamy
