Warning message
Using LMS to send out interface commands to switches
Answered Question
Nov 13th, 2006
Hi, I am trying to figure out how to make LMS send out interface commands to 3750 stacks with different numbers and models of switches in them. For example, I want to enable spanning-tree portfast on all the fastethernet ports. Any ideas? Thanks
Correct Answer by Joe Clarke about 10 years 9 months ago
You can use the Baseline Template feature of RME to do this. Your template would look something like:
Submode: interface [#FastEthernet1/0/.*#]
+ spanning-tree portfast
Once you have the template defined, you can deploy the necessary changes to all interfaces that are not compliant (i.e. that do not have portfast enabled already).
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Mon, 11/13/2006 - 14:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
aaron.storey Thu, 11/16/2006 - 06:22
Is it possible to apply a configuration like this, but matching only on interfaces that are set to access mode?
Thanks.
