Warning message
How to pass ISDN Caller ID Name to 3640 sip-ua
Answered Question
I am not able to get Caller ID name to pass from a ISDN PRI connected to a 3640 (12.4 ios) through to the sip-ua. Caller ID number works & passes fine. I see the caller ID name come through on isdnq931 and ccsip debugs as shown below:
Nov 13 17:56:29 CDT: ISDN Se1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x5C19
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Facility i = 0x9F8B0100A115020101020100800D505249534D4E45542020494E43
Protocol Profile = Networking Extensions
0xA115020101020100800D505249534D4E45542020494E43
Component = Invoke component
Invoke Id = 1
Operation = CallingName
Name presentation allowed
Name = PRISMNET INC
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '5128219133'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '5126470901'
Nov 13 17:56:29 CDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP Y.Y.Y.Y:5060;branch=z9hG4bK646B1BF1
To: <sip:[email protected]>
Date: Mon, 13 Nov 2006 22:56:29 GMT
Call-ID: [email protected]
Supported: 100rel,timer,replaces
Min-SE: 1800
Cisco-Guid: 144998049-1923158491-2832072705-1108514560
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY
, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:[email protected]>;party=calling;screen=yes;privacy=off
Timestamp: 1163458589
Contact: <sip:[email protected]:5060>
Expires: 300
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 253
From what I can only guess, the
(screen=yes) is the culprit. Does anyone know how to set the call screen=no, or how to make it pass the Caller Name through? Here's all I have for my sip-ua:
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers expires 300000
sip-server ipv4:X.X.X.X:5060
Correct Answer by gogasca about 10 years 9 months ago
The screening indicator is generally not used to decide whether to show the calling party's number|name at the called entity. Rather, it's purpose is to tell the called entity whether the calling party number was set by the calling user (and possibly verified by the network), or if the number was set by the network (for example if an invalid calling number was sent by the calling user and the network over-wrote it).
According to Q.951 clause 3, the originating local exchange is to discard any screening indicator it might receive from the calling user. This is of course not to be confused with the Presentation Indicator (Allowed/Restricted).
There is no way currently in IOS CLI to set the screening indication bit as far as I know. But these values can be set to customer-required values by using TCL script. Use the default "session" script in IOS gateway, modify it according to your requirement and then load the session application in the incoming dial peer of the gateway.
Use "set callinfo" to set the values of Octet 3a and then associate with the setup message using "leg setup" command.
IE:
set callInfo (originationNumSI) "usr_provided_screening_passed"
Refer the following links,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/vapp_dev/tclivrv2/chapter3.htm#1036917
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/vapp_dev/tclivrv2/index.htm
"0" (user-provided, not screened) on "1" (user-provided, verified and passed).
SIP can support calling name in Facility-IE
Per your debug:
The name is coming in a FACILITY message after the initial set up message so the INVITE needs to be buffered until the receipt of the calling name, we need to configure:
- "isdn supp-service name calling" under isdn d-channel interface
- need to configure under sip-ua
no remote-party-id
timers buffer-invite 5000 (or anything more than the timeperiod in which the FACILITY
comes in after the q931 SETUP).
Calling name should work now as a buffered INVITE is sent with the calling name in the
FROM field.
Let me know
//G
Overall Rating: 5 (2 ratings)
Correct Answer
gogasca Mon, 11/13/2006 - 18:28
  • Green, 3000 points or more
IE:
Per your debug:
no remote-party-id
FROM field.
Let me know
//G
