VTP trunking on a 4507 switch
Answered Question
Nov 14th, 2006
I have a quick question if you set up a trunk port on a 4507 switch, when the trunk is set will it reset the whole switch for a few seconds. Also if you trunk to a 2950 do u have to use croso over. sorry to ask such a basic question
Correct Answer by mahmoodmkl about 10 years 9 months ago
No the switch will not be restart.just the port wil go up/down for few seconds.
yes for connecting between two switches u need to use cross cable.
Mahmood
Overall Rating: 5 (1 ratings)
Correct Answer
mahmoodmkl Tue, 11/14/2006 - 02:48
  • Gold, 750 points or more
Mahmood
