Warning message
Simply question about SSL login to PIX
Answered Question
Nov 15th, 2006
Hi all!
I'm used to config pix throuh telnet, but now I've only HTTPS access to it.
How can I login to it? (what should I use for login and password)? I'm know only enable password, but don't know for sure pix hostname or any other things... There are no any "username" or additional to default config "aaa".
Correct Answer by m.sir about 10 years 9 months ago
Enable password is enough
type in your browser
https://PIX_IP_address
when you are prompted for username/password let the username field empty and like password enter enable password... You will be probably prompted again (by java applet) so enter this password again
M.
Hope that helps rate if it does
Overall Rating: 5 (1 ratings)
Correct Answer
m.sir Wed, 11/15/2006 - 03:35
  • Gold, 750 points or more
M.
