Warning message
isdn pri Nortel pbx troubleshooting
Nov 15th, 2006
I have a 2821 router with an E1 card connected to Nortel 11c pbx.I have configured ISDN E1 PRI between PBX & cisco router.
Problem - The ISDN link between the router & pbx is not comming up(all the 3 ISDN layers are down).
The cable between the router & PBX is a tested working cable.
Below is the brief config-
network-clock participate wic 0
controller e1 0/0/0
pri-group time slots 1-31
interface serial 0/0/0:15
isdn switch-type primary-net5
isdn incoming-voice voice
isdn protocol-emulate network
I tried configuring the router as user ,tried with the command "network clock-select e1 0/0/0 but still not working.
Please let me know if any one has faced this problem
Regds
Kiran
Overall Rating: 4.5 (4 ratings)
rnarayana Wed, 11/15/2006 - 10:50
  • Bronze, 100 points or more
If you layer 1 is not coming up then it is either a switch type mismatch or cabling issue.Make sure on the nortel side it is set to isdn user side.Also you need to program the "network clock-select 1 e1 0/0/0 for the clocking and if the router is providing clocking under controller e10/0 you need to program clock source internal.
check the cabling and switch type to bring up layer 1 first.Hope this helps.
R
ReadersUK Thu, 12/07/2006 - 08:22
Hi Kiran
i am about to attempt exactly the same setup as you. did you ever get this working and if so what advice can you give me.
regards
Colin
sasaadamovic Thu, 06/14/2007 - 08:06
Hi Kiran and Colin
I am also attempting similar setup as you with only diffrence being I am configuring 2811 routert. Can you give me any advice please.
regards
Sasa
ReadersUK Thu, 06/14/2007 - 08:22
I will be trying to wire this config up on moday next week, if you can wait ill share what i learn with you,
regards colin
sasaadamovic Fri, 06/15/2007 - 01:20
Thanks Colin. I am lookinf forward to see this config.
Sasa
ReadersUK Tue, 06/19/2007 - 07:52
Hi Sasa
Heres what i have so far, connected the Dual PRI to Routers MFT-E1 card and got CD light at both ends. unfortunately there are alarms and when i do show isdn stat cisco shows all layers down. Ill attach my config of both router and nortel meridian option81. Ill also include the pinouts i used. Take a look any feed back appreciated.
Colin
paolo bevilacqua Tue, 06/19/2007 - 07:55
  • Hall of Fame,
    Founding Member
can send "show controllers e1" on the router ?
ReadersUK Tue, 06/19/2007 - 08:39
Here you go, also at bottom is nortel side
E1 0/0 is down.
Applique type is Channelized E1 - balanced
Receiver has remote alarm.
alarm-trigger is not set
Version info Firmware: 20040713, FPGA: 15, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (604 seconds elapsed):
PRI2 LOOP 3 - ENBL
REF CLK: DSBL
SERVICE RESTORE: YES
ALARM STATUS: OOS LOCAL ALARM : LOS
CH 01 - DSBL TIE VOD * CH 02 - DSBL TIE VOD *
CH 03 - DSBL TIE VOD * CH 04 - DSBL TIE VOD *
CH 05 - DSBL TIE VOD * CH 06 - DSBL TIE VOD *
CH 07 - DSBL TIE VOD * CH 08 - DSBL TIE VOD *
CH 09 - DSBL TIE VOD * CH 10 - DSBL TIE VOD *
CH 11 - DSBL TIE VOD * CH 12 - DSBL TIE VOD *
CH 13 - DSBL TIE VOD * CH 14 - DSBL TIE VOD *
CH 15 - DSBL TIE VOD * CH 16 - DSBL TIE VOD *
CH 17 - DSBL TIE VOD * CH 18 - DSBL TIE VOD *
CH 19 - DSBL TIE VOD * CH 20 - DSBL TIE VOD *
CH 21 - DSBL TIE VOD * CH 22 - DSBL TIE VOD *
CH 23 - DSBL TIE VOD * CH 24 - DSBL TIE VOD *
CH 25 - DSBL TIE VOD * CH 26 - DSBL TIE VOD *
CH 27 - DSBL TIE VOD * CH 28 - DSBL TIE VOD *
CH 29 - DSBL TIE VOD * CH 30 - DSBL TIE VOD *
CH 31 - DCH 23
paolo bevilacqua Tue, 06/19/2007 - 08:45
  • Hall of Fame,
    Founding Member
router has good signal from pbx but not vice-versa. Check again cabling the direction router --> PBX.
Also I think you need to set clock source internal on the router because pbx is taking clock from "Digital SuBscriber Loop".
paolo bevilacqua Fri, 06/15/2007 - 02:08
  • Hall of Fame,
    Founding Member
What is your current issue?
Perhaps we can give some tip to make it work in little time.
ReadersUK Tue, 06/19/2007 - 09:22
thanks for the reply
Basically it's down, layer 1 upwards. I take your advice on the cabling since i had a very large soldering iron. i am going to get a better soldering iron and re do the connections, tomorrow
regards
colin
ReadersUK Wed, 06/27/2007 - 03:06
I fixed cable issues with setup between E1 card and Dual PRI card on meridian. I attach Pinouts for anyone who is tring to make up a cable.
My current issue is the following error message on the CME system.
Jun 27 10:51:46 UTC: ISDN Se0/0:15 Q921: S7_T203_EXPIRY: Lost communication with remote.
Jun 27 10:51:46 UTC: ISDN Se0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=0
Jun 27 10:51:46 UTC: ISDN Se0/0:15 Q921: Net RX <- RRf sapi=0 tei=0 nr=0
paolo bevilacqua Wed, 06/27/2007 - 03:38
  • Hall of Fame,
    Founding Member
Seems like the cable is working now.
Please send "show controllers E1" and configure
Also configure "clock source internal" under controller E1.
and take the q921 trace again for a longer time (2-3 minutes)
ReadersUK Tue, 07/10/2007 - 05:33
The final piece to get this working was to change the T203 isdn timer on my controller. I have calls working both ways now.
my config looks like this now
interface Serial0/0:15
no ip address
no logging event link-status
isdn T203 30000
no cdp enable
Hopefully these posts should be enough for someone else to do the same setup.
colin
Rob Huffman Tue, 07/10/2007 - 05:38
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Colin,
Thanks for posting back with your solution! 5 points for this good info and for helping others in the future who may hit this issue.
Take care,
Rob
