IP Phone Agent
Rob Huffman Thu, 11/16/2006 - 13:41
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mike,
Every IP phone that will be used by an IP Phone Agent should be associated with the RM JTAPI Provider user...
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00801c5765.shtml#step3
The Cisco IP Interactive Call Distribution (ICD) Resource Manager (RM) uses a JTAPI user configured in Cisco CallManager to monitor agent phones, control agent states, and route and queue calls. You must create a Cisco CallManager user for the Resource Manager subsystem. You can use any name. However, if you name the user RMUser, it is meaningful and easy to remember.
From this doc;
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080223b87.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.....
Chris Deren Thu, 11/16/2006 - 18:30
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
The "telecaster" user is needed for Enterpise Data, if you don't use Enterprise Data screen pops then you don't have to worry about it. Even if you use Enterprise Data it seems to be working without the user, but from what I understand you need it.
HTH,
Chris
