11-17-2006 09:47 AM - edited 02-21-2020 01:18 AM
I have a 515E with many VPN connections set up.
How do I reset a single connection without effecting the other sessions?
I have tried "clear ipsec sa peer " command but all the sessions reset!!
11-17-2006 10:43 AM
The command is "clear ipsec sa peer " or "clear crypto ipsec sa peer . But if it doesn't work, try clearing them via individual SPI.
http://www.cisco.com/en/US/customer/products/ps6120/products_command_reference_chapter09186a008063f0de.html#wp2037443
- Issue "show ipsec sa", and check the session of peer "current_peer" you intend to disconnect.
- Look for its SPI under "current outbound spi:".
- Clear the session's SPI using "clear ipsec entry
AK
Log in to Community
