11-17-2006 12:20 PM - edited 03-11-2019 01:57 AM
PIX 501 Config not saving
I have tried over and over and over again reseting back to default and it will not save the default. any ideas?
11-17-2006 12:31 PM
Are you trying to reset the config to default@factory default with basic config?
Try 'write erase' and confirm yes 'y'. Reboot the box - it will boot with factory basic config.
Hope this helps. Pls rate useful post(s).
AK
11-17-2006 02:36 PM
Factory reset looks like:
interface ethernet0 auto shutdown
interface ethernet1 auto
interface ethernet2 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password xxx
passwd xxx
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
no ip address outside
ip address inside 192.168.1.1 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
But the POST before should give the same results.
11-19-2006 05:25 PM
Try removing your dhcpd config with the NO command " No dhcpd enable" etc then do the wr erase.
I can not tell which Version IOS but also clear configure all then wr erase.
Bill Harrison
Cisco Instructor
