Problem in GBIC module of 4506 switch
Nov 18th, 2006
one of my client is facing problem in module 2 of 4506 switch with supIV(image is cat4000-i5k91s-mz.122-20.EWA.bin). the logg file is attached. it gives:
Nov 17 01:37:48.719: %C4K_GBICMAN-3-S2WERROR: S2w bus error while looking for changed gbics on port Gi2/2: S2wErrorNoAckDevAddress
The module remains stuck(hang)for an hour and resumes working normally after that. the problem is intermittent. so i m not able to find the soltion for that.
pls help.
govind
Overall Rating: 5 (2 ratings)
amit-singh Sat, 11/18/2006 - 02:18
  • Blue, 1500 points or more
I have already posted it for you in WAN routing
This seems to be transient cosmetic issue with the module.
CSCdu63962.
To verify that this is the HW problem,
1) Extract and re-insert all of the GBICs. You
should hear a clicking sound and the GBICs should feel snug in their slot.
2) If you continue to see the log messages, "S2w bus error...", then try moving the affected linecard to another slot in the chassis.
3) If you still see the log messages, "S2w bus error...", then you are hitting HW failure
HTH, Please rate if it does.
-amit singh
smothuku Sat, 11/18/2006 - 09:16
  • Silver, 250 points or more
Hi Govind,
This message means that there was an internal communication error when the software read
the GBIC/SFP control data.
**** Better go for replacement of line card.
satish
