amit-singh Sun, 11/19/2006 - 05:51
  • Blue, 1500 points or more
Which OS you are running on the switch.
Is it Hybid (CatOS+IOS) or Integrated IOS.
If you are running hybrid then use the following command:
Console> (enable) show traffic
Threshold: 100%
Traffic Peak Peak-Time
0% 0% Tue Apr 25 2000, 12:07:32
Console> (enable)
Foe IOS
Show fabric utilization
HTH,
-amit singh
NBouassiba Mon, 11/20/2006 - 01:01
catOS& IOS are running on the switch,
the command "sh traffic" ist fine, I used on the switch,
Thanks for your help
Nouri
