HREAP Question
Answered Question
Nov 20th, 2006
i am designing a centralised wirless network which consists of a AIR-WLC4404-100-K9 at the HQ and 50 sites which contain 1 or 2 AIR-LAP1131AG-E-K9.
Could you please confirm that HREAP comes with these AP's and that additional software does not need to be purchased. I know that with Aruba this is the case
Correct Answer by jolmo about 10 years 9 months ago
Hi Nathan
H-REAP is supported only on the LWAPP-based 1131AG and 1242AG Access Points. Running 4.0 code or later, the 2000 and 4400 Series Controllers, Catalyst 3750G Integrated Controller Switch, Catalyst 6500 Series Wireless Services Module (WiSM), and Wireless LAN Controller Module (WLCM) for Integrated Services Routers (ISRs) all support this H-REAP functionality.
While there are limitations on how many H-REAPs can reside at a single site, there are no similar limitations on the number of H-REAPs supported by controllers. H-REAPs are treated the same as other access points when it comes to how many a given controller can support.
For more info:
http://www.cisco.com/en/US/products/ps6521/products_tech_note09186a0080736123.shtml
Hope this helps
Overall Rating: 5 (1 ratings)
Correct Answer
jolmo Mon, 11/20/2006 - 03:32
  • Silver, 250 points or more
Hi Nathan
For more info:
Hope this helps
nathan.deane Mon, 11/20/2006 - 03:42
Brilliant,
I actually put the wrong part code in my original mail, and have included teh LWAPP enabled AP's.
Its good to know that i need code 4.0 or later..
Thanks for the clarification
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
