Warning message
Reactive script problem
Nov 20th, 2006
anyone seen the following issue when trying to do a reactive script debug remotely on IPCC 4.5
Engine hostname list is empty
check the LDAP for enabled CRS engines
Erik
bwalchez Mon, 11/27/2006 - 06:21
Try this:
From the Cisco Intelligent Contact Management (ICM) Configuration Manager, choose Tools > List Tools > Network Voice Response Unit (VRU) Script List.
Temporarily increase the value in the Timeout field for the script.
belz-e Mon, 11/27/2006 - 07:00
Im sorry I should have specififed this is the Express platform version 4.5
jrockhill Fri, 12/01/2006 - 14:02
I am running into the same issue, TAC says its DNS related (the second NIC picked up a DHCP address that became related to the LDAP somehow), still awaiting some kind of resolution, I have rebooted the machine, reset and cleared DNS and disabled that bothersome NIC, error has not changed. Running 4.5 CRS with CCM 5.03
John Irey Mon, 06/11/2007 - 10:21
Ever find an answer for this? I saw this today on a new install.
gokulakrishnan.g Mon, 07/30/2007 - 02:46
Guys,
We are facing the same problem. Did anybody resolve this? We are using IP IVR 4.5.
Gokul
John Irey Mon, 07/30/2007 - 07:38
For us, it ended up being a port issue between VLANs.
gokulakrishnan.g Mon, 07/30/2007 - 08:13
It is good to know that there is a fix to this problem :) Having said that, what causes this error? Does the client machine and the Server need to be in the same VLAN? Are there any other restrictions like this? Like for example, do they have to be in the same domain?
The client machine is able to login to the server ( as in the client CRS editor is able to login to the server), so what is the reason for the error?
Thanks in advance
Gokul
sementellic Thu, 09/04/2008 - 11:15
Can you elaborate on what the issue was with the ports and vlans? Do you mean that the port the server was on and the ports the phones are on are in 2 different vlans?
hari.kanan Mon, 07/30/2007 - 08:22
did you try installing the crs editor in some other server(in the same network and domain) other than the crs server.
hari.kanan Thu, 08/02/2007 - 04:04
hi,
guys i couldnt find a solution for this problem, so i re-installed. now my isuues is resolved.thanks
