Warning message
zubairjalal Tue, 11/21/2006 - 02:25
  • Bronze, 100 points or more
Yes it is possible. What you can do is copy data from your existing flash to a tftp server and then copy the data from the tftp server to the other switch flash.
copy flash tftp is the command to copy from flash to tftp server
copy tftp flash is the command to copy from tftp server to flash.
Also, some IOS support the switch to become a tftp server. you need to check if your switch has the tftp server command...
--Pls rate if useful--
ankbhasi Tue, 11/21/2006 - 02:48
  • Cisco Employee,
Hi Suresh,
Which switch it is? There is also an option to configure switch directly as a tftp server and then copy the image from one switch directly to another switch.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/fun_c/fcprt2/fcaddfun.htm#3767
But not all switches and ios version support this.
Ankur
*Pls rate all helpfull post
