Warning message
Fax problem on VG248
Hi All,
I have a strange fax problem. Usually this fax works well, but sometimes (2-4 a day) the other side gets an transmission error report, while my side receives the fax. Both Side have Canon faxes.
My side uses Vg248 with fax-passthorugh, receives the fax through a PRI , the other side uses Cisco 2600, with FXS module, BRI, and fax-passthrough.
can it be a configuration problem, or line noise?
On the incoming PRi gateway I use passthrough also.
The config:
dial-peer voice 103 voip
tone ringback alert-no-PI
description -=Kimeno FAX hivas CCM1 fele=-
translation-profile outgoing FAX-WAN
destination-pattern 5T
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:10.223.248.10
fax-relay ecm disable
fax rate disable
ip qos dscp cs3 signaling
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 3
rule 1 /^5\(.*\)/ /\1/
voice translation-profile FAX-WAN
translate called 3
translation-rule 5
Rule 0 * 5
voice-port 1/0/1
no snmp trap link-status
translate called 5
cptone HU
timeouts call-disconnect 1
description ---=== FAX Kozponti ===---
station-id name FAX
station-id number 34849
BRI:
voice-port 1/1/0
translation-profile incoming Bejovo
compand-type a-law
cptone HU
VG248:
Call ID, mwi: off/none, no gain,
relay and ecm disabled, nsf 000000, passthrough automatic.
Bela
Overall Rating: 5 (1 ratings)
