Warning message
IPSec+OSPF, using Tunnel GRE/IP or IPSEC/IP
Nov 21st, 2006
i'm using IPSec+OSPF. There're the two possible solutions for protocol/transprot using Tunnel Interfaces:
a) GRE/IP with crypto-map, or
b) IPSEC/IP with crypto ipsec profile
What are the advantage/disadvantage using a) or b)...?
My main connection is based on direct Ethernet, but the backup solution depends on an E1 dialer-profile, so it's difficult to use dynamic routing for transport tunnel-source/-destination addresses and avoid from routing these addresse through the tunnel...
regards
Frank
a-vazquez Mon, 11/27/2006 - 10:17
  • Silver, 250 points or more
IPSec supports the encryption of unicast IP traffic only. Therefore, routing protocols like Enhanced Interior Gateway Routing Protocol (EIGRP) and Open Shortest Path First (OSPF) and non-IP traffic like Internetwork Packet Exchange (IPX) and AppleTalk are unable to be encrypted using IPSec. Encapsulate such traffic in Generic Routing Encapsulation (GRE) before encryption, using a GRE over an IPSec configuration. With GRE over IPSec, traffic will be encapsulated first and then encrypted.
Try this link:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800a43f6.shtml
