Warning message
Moved CSM's from 6509 to 6513
Answered Question
Nov 21st, 2006
I just upgraded to a 6513 with sup720's. I moved both csm's and config info to the new config. Everything is working but before the move I could see both csm probe details and they were both operable. Now after the move only the active say's operable and the standby says failed. How do I get this back so that both are operable?
Correct Answer by Gilles Dufour about 10 years 9 months ago
you will have to do some troubleshooting.
Get on the standby.
See if it can ping the server.
'ping mod csm X x.x.x.x'
Check csm arp table.
Check L2 mac-address table between CSM and server.
finally, sniff on the server to see if it gets the probe and if it does send a response.
Once you know exactly why it fails, you'll know how to fix it.
Gilles.
Overall Rating: 4 (1 ratings)
Correct Answer
Gilles Dufour Wed, 11/22/2006 - 02:24
  • Cisco Employee,
Get on the standby.
Gilles.
gsuarez0514 Wed, 11/22/2006 - 09:53
Thank you. I must have over looked the config on the standby csm. The server address on the standby csm was not set. It looks good now. Thanks again.
