non-root bridge association problem
Nov 22nd, 2006
I have an installation using Cisco 1242 Access Points (IOS) as bridges
in 5Ghz band, and as AP in 2,4 GHz band. Sometimes I get problems
with the non-root bridges, after mains outage, they will not
associate to the root bridge. Command "dot11 do 1 carrier busy"
issued to the non-root bridge helps, but sometimes I have to use it
several times. Have anybody any idea about possible cause?
frankzehrer Wed, 11/22/2006 - 21:47
  • Silver, 250 points or more
Hi Frantisek,
what IOS version do you use?
In the past i solved some issues with a actual or older IOS image!
Have a look on the release note if you try to use an older image.
I have running the above mentioned config with 1232 APs and a 12.3(8)JEA image.
Best regards,
Frank
fopravil Thu, 11/23/2006 - 03:29
Hi Frank,
I am running 12.3(8)JA2; I is a good idea to try new sw version, I will try it (probably during next week).
I suspect there is some interference causing this effect, but i have no suitable measurement equipment to prove it.
Best regards
Frantisek
fopravil Sun, 01/14/2007 - 13:22
Hi Frank,
I think I have found the reason of my troubles. It is the following configuration command:
(interface Dot11Radio1)
world-mode dot11d country CZ outdoor
which is not only not-needed on the non-root bridge AP, it prevents associating the non-root bridge to the root-bridge AP. It does not cause the troubles on each root non-root couple. The troubles are more frequent with IOS version 12.3(11)JA or 12.3(8)JEA than with 12.3(8)JA2.
Frantisek Opravil
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
