Warning message
Adapt Diplayname in DCR after DNS change?
Answered Question
Nov 24th, 2006
Hi! Is there a possibility that the displayname in dcr will automaticly adapt to the DNS name? After a DNS name change, I always have to adapt the displayname manually in DCR. Thanks
Correct Answer by Joe Clarke about 10 years 9 months ago
This can be made to happen if you are using Campus Manager Device Discovery, and you have the following set in DeviceDiscovery.properties:
nameserver.updateDCRDisplayName=true
nameserver.updateDomainNameSuffix=true
The second property is optional, and will also allow the domain name to be updated as well. DeviceDiscovery.properties can be found in NMSROOT/campus/etc/cwsi. You do not need to restart any daemons after editing this file.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 11/24/2006 - 11:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
miheg Sun, 11/26/2006 - 23:57
  • Gold, 750 points or more
Will this also work for DFM now?
I think until now I have to remove and add a device from DFM to get it updated.
Cheers,
Michel
Joe Clarke Mon, 11/27/2006 - 00:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This will not work for DFM since DFM does not respect Display Name. Yes, you will need to delete and re-add for DFM to recognize the change.
