Upper limit to dot1q sub-interfaces on 2600?
Answered Question
Nov 24th, 2006
Is there any restriction to the number of FastEthernet dot1q sub-interfaces you can configure on a 2600 series router?
Thanks!
Correct Answer by ankbhasi about 10 years 8 months ago
Hi Steve,
It all depends upon the IDBs (Interface Descriptor Block) on each platform. But in general you will get enough that you can accomodate your requirement easily.
Check this link and it will give you the details or each and every platform
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml#max_no_interfaces
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 11/24/2006 - 20:15
  • Cisco Employee,
Hi Steve,
Ankur
steve.dutky Mon, 11/27/2006 - 06:25
~800? Looks like about 750 more than I will ever need.
