Connecting to Internet ISP through Router2800 with WIC-1AM
Answered Question
Nov 27th, 2006
Given the following show commands and config file. Why can't I surf the Internet through the LAN port on the Router?
Correct Answer by rwyates_2 about 10 years 8 months ago
I do not see an IP NAT OUTSIDE configured on any of your interfaces. I am guessing you are using Dialer 1 for your outside interface. You will need to add IP NAT OUTSIDE to it.
This link will help verify if NAT is working
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094c32.shtml
This will help configure NAT.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic13
I hope this helps.
Overall Rating: 3 (1 ratings)
Correct Answer
rwyates_2 Mon, 11/27/2006 - 12:08
  • Bronze, 100 points or more
I hope this helps.
Eloy Pascal Thu, 11/30/2006 - 06:41
hi rwyates,
i did what you told me.. but still (the Internet Account Works fine with the PC) but when I connect the Router and make the call and Log In, i cannot surf the web through the PC.
This is what a cybercafe configuration should have, there must be something wrong in there, anyone have a cybercafe configuration to look at? This is Internet Dial UP, not ISDN.
I post the config file and some troubleshooting commands..
Thanks...
Eloy Pascal Thu, 11/30/2006 - 10:25
you guys it worked!!
I was using the wrong DNS server from the ISP.
Thanks to all.
