GFI faXmaker integration with 2811 voice gateway
Nov 27th, 2006
the scenario is termenate the fax line comes from PSTN intovoice gateway and configure T38 and fax detection application the goal of this is just to play IVR to instruct the dialer from PSTN to enter the fax extention after hearing the peep sound from GFI faXmaker modem because its not capabale to record any voice response.so please inform me about my configuration and tell me if it will work and if it not please inform me with correct solution. you will find in the attachment the scenario and my suggest configuration.
NOTE:
in the real scenario there is only one line to GFI faXmaker and the modem is internal modem not external.
the FXS port is RJ11 and modem is RJ45 so please advice me which correct cable i have to use if these scenario will work.
